Single 450 + E85 - 650rwhp doable?
Old Jul 2, 2019 | 11:55 AM
30th t/a's Avatar
Default Single 450 + E85 - 650rwhp doable?
Single 450 running E85 with 80lb injectors. Think it be okay for 630-650rwhp through a 6 speed?
Old Jul 2, 2019 | 04:40 PM
Kfxguy's Avatar
450 What?
Old Jul 2, 2019 | 07:57 PM
30th t/a's Avatar
Originally Posted by Kfxguy
450 What?
Walbro
Old Jul 2, 2019 | 09:17 PM
Kfxguy's Avatar
Originally Posted by 30th t/a
Walbro
Lol. I’m an idiot.
Old Jul 3, 2019 | 08:50 AM
panda240ss's Avatar
in my opinion i always get a bit bigger system in case i wanna go bigger power down the road.
for example. im doing 142lbs injectors with dual 450s thru a th350 just to make sure i dont run out of pump or injectors and i just want 700 750
Old Jul 3, 2019 | 12:09 PM
AUS Injection's Avatar
Message sent
Old Jul 4, 2019 | 12:40 AM
KimmoT's Avatar
I was getting 620hp single Walbro 450 with BAP and e85. I have to lower base fuel pressure 4->3 bar to get more flow to pump. Then FIC 1000cc injectors almost 100% IDC
Old Jul 4, 2019 | 05:46 AM
30th t/a's Avatar
What transmission were you running when you made 620rwhp?
Old Jul 4, 2019 | 06:13 AM
KimmoT's Avatar
Stock Corvette C5 T56 with spec clutch.
Old Jul 4, 2019 | 08:29 AM
30th t/a's Avatar
Anyone have experience with the Walbro 525? I searched on this site but theres very little info on it.
Is it a drop in replacement like the 450?
Old Aug 6, 2019 | 10:07 AM
30th t/a's Avatar
Walbro 525??...Anyone with experience with this pump?
Old Aug 6, 2019 | 10:28 AM
JoeNova's Avatar
Restricted User
The 525 is a stock Hellcat fuel pump. There shouldn't be any concerns with an OEM pump.
Old Aug 6, 2019 | 12:09 PM
30th t/a's Avatar
Do you know if I can run this Walbro 525 in my 02 WS6? Is it a drop in (like the walbro 450)?
Im hoping this will fit in the bucket and I can hook up a hot wire kit and be done and be good for 630-650 on e85.
They say the pump supports 700+ on e85.
Old Aug 6, 2019 | 02:19 PM
fif_gen_powa's Avatar
It's same size and direct swap for a walbro 450. Make sure you have 10ga wires and proper size fuse
Old Aug 11, 2019 | 10:10 PM
dumetre's Avatar
Was that with stock lines?
Old Aug 12, 2019 | 11:22 AM
KimmoT's Avatar
Yes i had stock lines from tank to engine bay. When add adjustable fuel pressure regulator, then only change fuel rails and those short fuel lines.
Old Aug 12, 2019 | 05:14 PM
imma_stocker's Avatar
Maybe these will help.
Walbro 450lph pump flow chart
and the Hellcat pump
Old Aug 14, 2019 | 06:12 AM
joyridin''s Avatar
The outlet line on a 525 is larger than a 450. I was going to go with one, but most of the modular fuel pump assemblies do not have a large enough line. They went from a 10mm to an 11 mm outlet. Doesn't seem like much until you try cramming that rubber fuel line over the outlet and realize it isn't going to fit.
