Fast Fuel Rail Leaking
Old Nov 2, 2019 | 09:26 AM
Dirtyberger's Avatar
Default Fast Fuel Rail Leaking
I put an LS7 in my 2001 Camaro SS with the Fast 102 intake manifold and fast fuel rails. I noticed that the fuel injectors are pulling out of the rail and spraying fuel everywhere. Doing a little research I found out that’s a pretty common issue with these rails. We have re put them in and made sure they are tight multiple times and they keep doing the samething. Does anyone know if there is a better rail that will work with this set up? I don’t think I want to risk using these rails.
Old Nov 10, 2019 | 10:52 PM
Undertow74's Avatar
They will leak. I once had that issue also with the front injectors. Had to put a small washer under both rear stanchions to level it out and make them seal correctly
