Decapped fuel injectors flow results
Old Dec 23, 2019 | 01:45 PM
Lsx Rubi's Avatar
Default Decapped fuel injectors flow results
I am currently running some 65lb FAST injectors and running out of fuel around 14lbs on a 5.3 S475 setup on pump gas. So I jimmy rigged a flow tester to test some flex fuel injectors from a LC9 I had laying around . After decapping them they flowed around 880cc/min which is about 86 lb/hr @58 psi and 800cc or 76 lb @ 42 psi . Searching around most people have had higher flow numbers in neighborhood of 90-100 lb/hr . Also 6 injectors flowed within 1-2% of each other but one flowed 5% over and the one was 5% under than the other 6 . Is it safe to run them as is ?
Old Dec 13, 2023 | 05:35 PM
iigw's Avatar
...and what did you find out??
did you run them?
Old Dec 13, 2023 | 07:34 PM
Lsx Rubi's Avatar
did you run them?
Yes I did , and they ran awesome . Perfect afr control at a 600 rpm idle. Ran 14 psi of boost on pump gas and water meth for a of year or so. Decapped some ford coyote injectors after which are 100 lb/hr,, running those currently .
Old Jun 3, 2024 | 10:11 AM
TheBestFoxEver's Avatar
do you think I can get your injector data?
