50lb Injectors
Old Mar 10, 2020 | 10:13 PM
Karas.gto's Avatar
Default 50lb Injectors
So I have a 2004 GTO that has a Torquer V2 cam, stock heads, ls6 intake, headers, full exhaust. I have a brand new set of 50lb injectors I got on trade. Would these be too much for the car? Haven't been on dyno yet. Just wondering if I should install before then or keep on shelf.
Old Mar 11, 2020 | 07:02 AM
rel3rd's Avatar
No idea what size injectors you have now, but I had a set of 60#ers, first with gasoline (maximum of 40-ish% duty cycle), then with E-85 (maximum of 60-ish% duty cycle) in my car with a 6.0, "Sloppy" Stage 2 cam, and all the basic bolt-ons. No problems whatsoever.
As long as whomever tunes the car has correct injector data for them, they should be a simple swap and give room for growth as well, IMO.
Old Mar 12, 2020 | 09:30 AM
AUS Injection's Avatar
A lot of injector for your application IMO. But as @rel3rd said, if you have real injector data for that set, your tuner should be able to get those to work. 50lbs injectors are good for around 600+ Hp at 80%IDC on a NA/Pump Gas setup, somewhere around there.
