Corvette Regulator Issue
A scientific principle is that when you increase pressure you reduce volume. So to increase volume the FPR allows the increase in volume while at the same time maintaining a static pressure on the outlet side of fuel injector.
If by chance you are using both together then you need to remove the Corvette filter and instead install a larger (volume capacity) than the stock fuel filter and let the FPR maintain pressure and volume.
https://www.turbosmart.com/news/how-does-an-fpr-work/
Some older model year trucks do have a fuel pressure regulator. Is yours one of them?
