Upgrading injectors
Old Jul 19, 2020 | 03:44 PM
UnZFeat'd's Avatar
Default Upgrading injectors
I would like to future proof my injectors. There is a really great deal for some good 80lb injectors. Can I install these with a stock motor? Do I need to tune it?
Old Jul 19, 2020 | 04:55 PM
Which engine do you have now, and which mods are you anticipating? You need to answer these questions before buying larger injectors, because too large doesn't work well either.
And yes, you ALWAYS need to retune when changing injector size.
You only need larger injectors if mods cause higher consumption than the present ones can handle.
Old Jul 19, 2020 | 05:30 PM
UnZFeat'd's Avatar
It is currently a stock LQ4. Planning on adding a turbo once I drop it into my 74 camaro, but right now it's in a 2004 silverado. The current injectors were in bad shape. Looking to get the truck driveable for now, and future proofed.
Old Jul 19, 2020 | 06:04 PM
I would look up AUS Injection in Tempe Arizona and see what they recommend as far as getting larger injectors at this stage. They also do cleaning.
