Too much fuel after decapping injectors
Old Aug 30, 2020 | 09:59 AM
jobermesik's Avatar
Default Too much fuel after decapping injectors
I have a 4.8ls turbo build in my gen 2 camaro. I recently decamped the injectors to get more fuel, and it’s too much fuel. The car won’t even stay running. Smokes from over fueling. Is there something I can do? Add a fuel pressure regulator to get it to run? Any help is appreciated!!!
Old Aug 30, 2020 | 02:16 PM
chevymec's Avatar
Pretty sure you will have to adjust the injectors in the tune.
Old Aug 30, 2020 | 04:50 PM
1987firechicken's Avatar
It has to be tuned there is no other option.
You just roughly tripled the flow of the injectors, you have to tell the PCM that they are that much bigger or you get what you have.
Also I hope you sent them out to be flow checked to make sure some of them are not way off and in tolerance/balance with each other. That cap acts as a restriction and also as a kind of make shift way of ensuring injector flow at the same time. Normally they are pretty close from what I have seen but you don't know until you test them, and if they are not matched you risk burning a hole in something or washing down your oil and wearing things out. I'm all about saving money on injectors but I think you should spend a few buck to make sure you're not going to break anything more expensive down the road.
Old Aug 31, 2020 | 07:34 PM
vincez28's Avatar
need a tune 100%
