losing fuel pressure
Old Oct 1, 2020 | 11:47 PM
augielsx's Avatar
Default losing fuel pressure
On my El Camino I have a 5.3 and I just got the terminator x and the fuel injection components on as it used be on the carb setup. truck starts right up and idles great good afr but when I rev the car i see the fuel pressure drops alittle not alot to shut off the engine but it does drop I havent driven the car yet to see if it does it when there's load but wanted to see what could be causing that. my fuel pressure is at 55 psi as im using the stock fuel pressure regulator. and im using deatshwerks 255 inline pump thats good for 100 psi at 255 lph
Old Oct 1, 2020 | 11:51 PM
Might be a bad regulator
Old Oct 2, 2020 | 12:02 AM
augielsx's Avatar
I actually installed a new one today that was rated for 51 to 57 psi and it was only giving me 41 psi of fuel pressure so I returned it and went back to the original one but I actually never noticed if it dropped fuel pressure with the new one I might have to try and get a new one on again and see if It drops fuel pressure.
Old Oct 2, 2020 | 08:37 AM
dlandsvZ28's Avatar
Dirty clogged fuel filter perhaps restricting flow and pressure.
