How are folks doing TBI effectively?
Old Oct 14, 2020 | 07:22 PM
17outs's Avatar
Default How are folks doing TBI effectively?
I've seen several wanting a vintage look doing a carb ls manifold, but what are they using for the TBI throttle body? I've seen the single plenum with spots for injectors and without so it seems some do the holley kit for TBI but its like 2500 bucks!
What are the cheapest ways of fueling if you want fuel injection but require a more classic look without the ls1 style manifold?
Old Oct 15, 2020 | 10:18 AM
Scott65's Avatar
You're question is a little confusing. Do you want TBI, or a carb "style" manifold throttle body with port injection? You could do either with the right manifold. Microsquirt is an affordable stand alone ecu that could drive either. You'll probably get more answers if you clarify what you're looking for exactly.
Old Oct 15, 2020 | 10:32 AM
17outs's Avatar
Sorry I am not trying to confuse. My question is 2 in 1. If you want a TBI style throttle body injection or a similar throttle body with port injection what are the most common vendors? Is the TB the same when you want it to be blow thru for turbo?
