1000whp fuel system questions!
Old Dec 5, 2020 | 09:21 PM
Sail Hatan's Avatar
Default 1000whp fuel system questions!
So I'm piecing together a fuel system for a turbo build (thank you Huron group purchase!) and I want it to be 1000whp capable. So far I have it pretty well planned, chrs1313 pump, -8an to filter, regulator, and up to holley rails and -6 back to pump. Now my question is, can I get away with coming in to one rail crossing over, and out of the rear of the other? Or should the feed go into a Y, into the rear of both rails, then return out of the front of both rails, Y back together and back to the pump? I’m hoping the first option is sufficient, but I’m willing to do whichever. Thanks! Pics of your set ups if you got them!
Old Dec 7, 2020 | 06:59 PM
BCNUL8R's Avatar
I had my rails in series and started having issues around 650 rwhp. I changed them to parallel and made over 800 rwhp with no problems. Definitely Y them to the back of both rails then out both rails to a boost referenced regulator and then out the regulator for return back to tank.
