Holley Lo-Ram Performance
Old Dec 26, 2020 | 07:06 AM
nicholasktu's Avatar
Default Holley Lo-Ram Performance
I am building a third gen Camaro with an LQ9 in it, with a cam design for 1200-6000 rpm power range, long tube headers, and full dual exhaust. I have a newer version of the Holley Lo-Ram (front feed version of it) because it is low profile and I got it for near nothing. How much power loss if any can I expect with the short runners on it? I am thinking about pulling it back off and using the truck intake I already have.
Old Dec 26, 2020 | 11:11 AM
You actually will be better off with the truck intake to keep your low and midrange power
Old Dec 27, 2020 | 08:49 PM
Lsx Rubi's Avatar
You will loose power all the way to 6000 rpm with a short runner intake compared to a long runner truck intake . Plenty of videos/ data out there , check out Holdener's stuff on YouTube.
Old Dec 27, 2020 | 09:11 PM
AwesomeAuto's Avatar
With that particular intake, you're going to lose power everywhere up to ~6400-6600 depending on cam/heads.
Old Dec 29, 2020 | 10:23 PM
I'm using a stock LQ4 crank with LQ9 pistons and rods, so it can't rev any higher than stock. I have a Comp 54-412-11 cam, 1200 to 6000 power range, stock LQ4 heads. I'll keep working on cleaning up the old LQ4 intake and throttle body, I'll put Holley fuel rails and a set of 36 lb-hr injectors on it. Should work better, I'll save my lo-ram for when I build boosted.
Old Dec 30, 2020 | 01:06 AM
I'd like to know why you think you can't rev those higher than stock lol. I've spun a stock shortblock gen 4 6.0 to 7200 and sprayed nitrous on top of that.
Old Dec 30, 2020 | 05:33 AM
I like the parts to stay inside the block. I don't think it can rev to what the lo-ram is capable of.
