42lb injectors
Thanks in advance.
On stock fuel pressure, the 36lb injectors are actually 41lbers...
This is actually my scaling IFR table out of HP Tuners for these injectors...
Injector Flow Rate vs. KPA VAC
40.11751 40.36553 40.61355 40.86158 41.10960 41.35762 41.60564 41.85366 42.03968 42.28770 42.53572 42.78374 43.03177 43.21778 43.46580 43.71383 43.96185
put it this way.....
On a 100 wet shot, on a stock fuel pump with these injectors I am only at 70% injector duty cycle at 520rwhp....im 412rwhp N/A and the Injector duty is 61%...you are fine.
FIC 80lb Siemens Deka EV1 High Impedance set of 8 (texas-speed.com)
https://turbo4less.com/product/sieme...or-set-for-v8/
Again why in the world would you buy a 36lb injector if you have factory injectors? (maybe you don't, just can't wrap my head around people buying an injector that will flow less than a de-capped factory unit)
