LSA injector height dimensions
Old Feb 12, 2021 | 09:12 AM
Fang's Avatar
Default LSA injector height dimensions
Anyone have the height/o-ring spacing of LSA/LS9 injectors, #12598646?
Or a reference that lists injector height/o-ring spacing dimensions for various injectors?
Old Feb 12, 2021 | 11:53 PM
RedXray's Avatar
Attachment 712074
Old Feb 13, 2021 | 12:46 AM
Fang's Avatar
Thanks!
I'm currently running the 50lb 12613412 flex injectors, just trying to think ahead to see if it'd be possible to squeeze these taller injectors into a LSA blower.
Old Feb 13, 2021 | 01:08 AM
RedXray's Avatar
Originally Posted by Fang
Thanks!
I'm running those same Gen 4 flex injectors in my Gen 3 Lq9 build. If you're running these on the Gen 3 platform you need to scale the injectors to work. The converted data is in the injector sticky here on the forums. If you're on the Gen 4 platform you're gold.
Old Feb 13, 2021 | 01:43 AM
Fang's Avatar
Yeah, 2006 E40 (Trailblazer). I stoled the injector data from a file Dave Steck posted way back when.
Old Feb 13, 2021 | 01:47 AM
RedXray's Avatar
Here is the data from "eaglegoat" in the sticky to compare if needed.
00 Trans Am GM#12613412 Injector Data
Old Feb 13, 2021 | 02:48 AM
Fang's Avatar
I've already tuned it N/A using DSteck's data in E40-specific format. From https://forum.hptuners.com/showthread.php?45447
