-6an feed limits on E85
Old Feb 18, 2021 | 04:00 PM
Bosshog's Avatar
Default -6an feed limits on E85
So on my current set up I’m running a -6an feed and return. Dual walbro 450s and haven’t decided on SEP 1500s or Bosch 210 injectors yet for my turbo 6.0 . Was wondering what the limits are on a -6an feed line on e85.
Old Feb 18, 2021 | 04:08 PM
01CamaroSSTx's Avatar
I've been told 1,000 whp is pushing it on the factory lines and if I were making that much I'd be 8AN anyway.
Old Feb 18, 2021 | 11:17 PM
Woodylyf767's Avatar
https://lmengines.com/pages/fuel-line-calculator
This calculator also suggest your fluid velocity may be turbulent with -6 lines which is a big nono
for 15 ft lines
9 psi pressure drop on -6 lines
2 psi pressure drop on -8 lines
.7 psi pressure drop on -10 lines
Seems like the walbro 450's become very inefficient at around 80 psi
If you ran 20 psi boost, with 60 psi base pressure and 20 psi pressure drop (from lines and fittings number pulled out my ***) you'd be in trouble.
I'm not a tuner and I'm not an expert
Old Feb 19, 2021 | 05:44 AM
Bosshog's Avatar
for 15 ft lines
okay so now I’m just confused. How can guys with stock rails and lines run high boost on the sbe cars and make 1000 hp but when I’m running a little bit larger line (-6an) it’s dangerous ? I’m running an adjustable FPR and I’m on a terminator if that means anything. I got big aftermarket rails as well..
Old Feb 19, 2021 | 08:00 AM
When I put the flow rate into the calculator I put 900 lb hr for 2 450's which wouldn't be accurate. At any normal base pressure (for efi) the flow would be less on those pumps. My bad.
They most likely have inefficient systems that's it. They just accept their pumps have to work extra hard and they may wind up with their base pressures dropping through a pull.
Just because the pumps are inefficient and there is a bunch of drag doesn't mean it won't work. It's just not ideal.
Like I said before I have a very analytical background. I'm not a tuner haha. Hopefully someone with more experience will chime in
Old Feb 19, 2021 | 09:00 AM
Bosshog's Avatar
Yeah I figured with mine being a return style the pressure will be constant vs it dropping in between shifts like on a return less style. I’d assume I’d be okay to run what I have rn but I get what your saying.
Old Feb 19, 2021 | 09:02 AM
Bosshog's Avatar
If anyone else has an idea feel free to chime in. Lol
