Fuel pump wiring.
Old Mar 27, 2021 | 07:07 AM
ldr's Avatar
ldr
Default Fuel pump wiring.
Im having some issues and could use some help. I am working on an 88 camaro. I only want to
do work once and am upgrading my fuel system. I have the fuel pump relay upgrade and an aeromotive fuel pump. My issue is I want to upgrade the wiring on the sending unit. I called racetronix and the rep said we have nothing for that old of a vehicle and no idea what plugs aeromotive use. Can any ome
point me to an upgraded bulkhead for the sending units and the correct harness for in tank that will supply the pump. My ls swap is using best parts I can get and since nothing local has parts to match I’m at online will. Thanks in advance.
Old Mar 28, 2021 | 09:18 PM
Racetronix's Avatar
LS1TECH Sponsor
Active Streak: 30 Days
Active Streak: 60 Days
You will require FPWH-005, BCWA-FL98HD and RCS-057. This will take care of the wiring upgrades.
The plumbing is another issue...
__________________
Manufacturer / Distributor of Automotive Fuel Systems, Components & Electronics
Please support a Racetronix dealer near you for personalized service.
>WEB SITE<
Old Mar 28, 2021 | 11:08 PM
ldr's Avatar
ldr
Thanks so much. Plumbing was the easy part.
