flex fuel injector question
Old Apr 2, 2021 | 10:40 PM
slotiper's Avatar
Default flex fuel injector question
so 2 years ago I had current performance build be a harness. finally putting the car together and realized they put the wrong injector plugs on it so what i need to know is are there any affordable 36-42ish lb injectors out there with Multec plugs on them to support a 400-500 NA motor I was thinking maybe an early truck flex fuel but ??? TIA
Old Apr 3, 2021 | 11:35 AM
dlandsvZ28's Avatar
A cheaper option would be to get adapters (plug and play) Call technical support from some of the leading injector vendors who can help you identity what you have now and then get the correct PN for the adapter to convert to the style injector you currently have.
Amazon Amazon
Old Apr 3, 2021 | 11:51 AM
slotiper's Avatar
my harnedd has the mini delphi plugs ( early truck. they do make an adapter but they looke like crap / the ev1 to ev6 look pretty ok
Old Apr 5, 2021 | 09:21 AM
AUS Injection's Avatar
You could always get pigtails instead of an adaptor and solder it to your harness for a cleaner look
