Do I need a fuel regulator?
Old Apr 12, 2021 | 07:35 PM
02BoostedZ28's Avatar
Default Do I need a fuel regulator?
I have installed an aeromotive 340lph intank pump into my 02 camaro stock fuel hat, I’ve been reading that I the stock fuel hats have 60psi fuel regulators built into them, I am changing all my fuel lines to braided lines, do I need to run an external fuel regulator or can I just plumb the return line into the stock fuel hat and be good to go?
Old Aug 2, 2021 | 03:15 PM
rv12's Avatar
following. Also want to know.
Old Aug 2, 2021 | 06:22 PM
01CamaroSSTx's Avatar
Yes you can still use the factory FPR on the pump assembly but what I did was remove the internals of the FPR in the pump and ran the Corvette C5 fuel filter which has a built in FPR and reconnected the return line to it. WS6Store makes a kit to make the switch and I'd rather just replace the filter with regulator then to have to pull the fuel pump assembly to replace a faulty regulator. If you decide to make the switch be sure and buy the WIX as they have proven to be the most reliable.
Old Aug 2, 2021 | 06:26 PM
http://www.ws6project.com/user_stor/...L-UPGRADE-KIT/
Old Aug 3, 2021 | 03:30 PM
rv12's Avatar
Great info, thanks. Hmm... decisions, decisions.
