Bosch 210's from VSRacing, need any adapters?
Old Apr 19, 2021 | 06:25 AM
rel3rd's Avatar
Default Bosch 210's from VSRacing, need any adapters?
EDIT***
Was able to get on an actual PC and do some quick research, so will leave this here to hopefully help the next guy (or gal)
STOCK LS1 fuel injectors are 2.55" long
Bosch EV1 # 0280158829 are 1.89" long
Stock - 64.77mm long
Bosch - 48.00mm long
Difference - 12.77mm
So...You'll also need the $50 set of 10mm long "hats", aka injector adapters..
original post, snipped...
They'd be replacing EV1 Snake Eater 1500's, which are a direct fit on my car, and same dimensions as a stock LS1 injector.
I have LS2 intake and Holley rails, and stock height is what worked.
I sent them an email, but they're 3 hours behind as far as time zone, and searches in my phone suck, and have been 100% inconclusive, lol
Their description, which is pretty much the same as anyone else's who sells these...
Used a common EV1 connector. Common use is for GM, Ford, etc.
Bosch Part # 0280158829
Same injector as Bosch 0280158821 except these are slightly longer and have EV1 connector.
