1000whp e85 what has worked for you
Old May 7, 2021 | 10:27 AM
Dwalt79's Avatar
Default 1000whp e85 what has worked for you
Goal is to have a fuel system capable of 1,000 whp through an auto on e85
what pumps and injectors have you used with good experience
Good source for ptfe line? Will an 8 feed and 6 return work?
Old May 7, 2021 | 10:37 AM
SLOW SEDAN's Avatar
8 feed 6 return certainly works, I've used the stock feed as the return and just run a feed line as well.
Numerous injectors and pumps will work. Do you want an in tank pump, in line pump, single or multiple pumps? Hi or low Z injectors? Price range?
Old May 7, 2021 | 10:57 AM
Dwalt79's Avatar
thanks for reigning me in lol..i need to give more detail
high z
Not set on intank or external or multiple pumps but want factor in durability and cost effectiveness
this will also see the street alot
Old May 7, 2021 | 11:33 AM
SLOW SEDAN's Avatar
1000hp on E the go to high z is Bosch 210's, unless you want to spend 4-5x as much on ID's version.
I'm a fan of single external pumps, keeps things simple. I've used Magnafuel, Aeromotive and Fuelab units in street cars without issue. I prefer brushless pumps but it adds to the cost a bit. The way I see it, you save a bunch on the injectors, get a nice pump!
Some guys like to have multiple in tank pumps often having one triggered under boost which will certainly work just more of a hassle.
Old May 13, 2021 | 09:36 AM
AwesomeAuto's Avatar
I made almost 900 at the wheels with a pair of AEM 400s and Deka 80s on E85.
High voltage and even higher fuel pressure helps. Several ways to it, but I definitely wouldn't recommend my route.
Old May 13, 2021 | 09:48 AM
SLOW SEDAN's Avatar
True I've made almost 1000 on a 255 in tank with a 400 inline with a boost a pump on it with 160lb injectors. Totally not recommended, but it works
Old May 13, 2021 | 10:11 AM
My pressure sensor only goes to 100 PSI, so I'm not actually sure how much fuel pressure I was running. I had already leaned out by a full point though, so the deka 80s were definitely more than topped.
