Need some direction.
Old Jun 23, 2021 | 07:27 PM
ramirop's Avatar
Default Need some direction.
I have an 02 Camaro ss, I’m doing h/c/I and headers upgrade and I ended up purchasing a set of 42lbs injectors. I bought a new stock fuel pump, will I need to remove and upgrade the fuel pump or can the stock handle it?
Old Jun 23, 2021 | 09:28 PM
Bob570's Avatar
Chances are pretty good that you'll run out of fuel with the stock pump. My fuel pressure was starting to dip at high RPM when my car was cam only, when I did the heads and intake I ended up just doing the fuel pump at the same time.
Old Jun 23, 2021 | 10:20 PM
ramirop's Avatar
what pump did you go with, if you don’t mind me asking? I saw this on their website, will that be enough
Old Jun 23, 2021 | 11:15 PM
98CayenneT/A's Avatar
Yup, that's what I run with the setup in my sig
Old Jun 24, 2021 | 06:55 AM
Bob570's Avatar
That's the kit I used too.
Old Jun 24, 2021 | 11:50 PM
ramirop's Avatar
One more question, I have the slp black wing air lid will I need to go bigger and the maf as well. I’m going to install the fast 102 with tb and I’m going to need the coupler. Any ideas where I can find the coupler?
Old Jun 25, 2021 | 12:35 PM
dlandsvZ28's Avatar
That's the same kit I had installed with 42lb injectors and was good up to 500 rwhp.
Engine mods as time were h/c, headers, etc. along with a D1 Procharger making about 6-8lbs of boost.
Later I replaced the 42 lbs with 60 lb Mototron injectors and made a pulley change upping boost about 1-2 lbs. The single Racetronix fuel pump with hot wire harness handled 565 rwhp and was still at about 80 percent duty cycle. Boost BTW requires more fuel and pressure than NA.
So with your current mods the Racetronix kit IMO is the best solution and will be good to at least 500 rwhp.
Tip: if you stay NA then IMO since the stock fuel pressure intank regulator ss now about 20 years old, I would remove it and replace with an external C5 Wix combination fuel filter/fuel pressure regulator.
If you replace the stock harness, make sure to replace the 99-2002 upgraded bulkhead connector that should be included with the hot wire kit . It can handle up to 30 amps compared to the stock connector which is much less and is prone to failure when running larger pumps that require more amps.
