Walbro 450 e85 hose
Old Jun 27, 2021 | 12:58 PM
fastlt1's Avatar
Default Walbro 450 e85 hose
Walbro 450 e85 submersible hose. The hose that came with the pumps let go on me last night at the track. The hose black rubber. Didnt feel right. Kind of squishy. After some research it seems alot of people are having problems with this type of hose. Question is. I want to replace it with the ptfe corrugated hose like they use from factory. I figure 9mm is size. I understand clamping it on the pump side but where I used a barbed fitting on the y side. It looks like it will cut the ptfe hose on shape edge when I tighten clamp. Are you using a different type of fitting? Any links to it?
