Bad Injectors?
Old Jul 7, 2021 | 10:31 PM
FcoRojas's Avatar
Default Bad Injectors?
Have an ls3 with fast 65lb Injectors
Btr stage 4 cam and all supporting mods.
Tuner says it stays rich no matter what he's tried.
I've swapped out MAF,MAP,both O2s, spark plugs wires
Whole *** harness.
Has no vacuum leaks all seems fine.
It misfires every now and then idles like ****, backfires like hell and when I let off the gas it stumbles and black smoke comes out the back end
Also exhaust reeks of top titty 93.
We swapped out the computer and Put the exact same tune in it and ran ******* amazing for like a day no stumbling even with the ac on no backfire then today to my disappointment back to the same ****.
The only things I haven't swapped out are the Injectors I have some 42lb sitting around anyone ever run into something similar??
Old Jul 8, 2021 | 06:48 AM
B52bombardier1's Avatar
Did your tuner person refer to the fuel injector flow parameters that came in the box? Those values need to be applied to the tune.
Rick
Old Jul 8, 2021 | 07:57 AM
shakenfake's Avatar
You got a full exhaust? Like discussed in a thread previously if you don't have some pipeage it is going to be a bitch to tune for your O2s
Old Jul 8, 2021 | 09:58 PM
FcoRojas's Avatar
Rick
Nope he just asked how many lbs the injectors where and that was it 🤔
Old Jul 8, 2021 | 10:00 PM
FcoRojas's Avatar
Yes sir full 3 inch x pipe all the way to the back,
Tuner said O2s weren't reading so we changed the whole engine harness everything works now still runs like ******* **** and it's a new motor too so it's just been sitting 😩
Old Jul 23, 2021 | 09:12 AM
blackbyrd's Avatar
65lbs is a lot of injector, does the setup actually need that much?
I have 60lbs on my 414 based off duty cycle calculation I could have gone smaller
Old Aug 1, 2021 | 04:34 PM
Old Buzzard's Avatar
NTT = New tuner time!
