Low Voltage at injectors HELP!
Old May 4, 2025 | 01:14 PM
Ponti C's Avatar
Originally Posted by IGN-1A
Hi, I would CHANGE to the Injector feed from the Battery.
Lance
how do I do that? Wire a 12v source to my injectors?
Old May 4, 2025 | 01:58 PM
IGN-1A's Avatar
Default Battery Pole Size
The battery in your car has TWO "poles", the larger one is B+.
Wire that one AFTER disconnecting the original feed to the injectors
Old May 4, 2025 | 02:04 PM
Ponti C's Avatar
battery posts? Aren’t they just positive and negative ?
so what your telling me is to jump a wire from a 12v source to my fuel injectors to bypass the original shorted wire
Old May 4, 2025 | 02:39 PM
91 Z28's Avatar
That's exactly what he's saying.
Old May 4, 2025 | 03:27 PM
The injectors are actuated by switching the GROUNDS, so a live 12V won't hurt it.
Old May 4, 2025 | 06:38 PM
Ponti C's Avatar
but won’t that leave my injectors with a constant 12v signal to fire? What about the signal from the ecu
Old May 4, 2025 | 06:43 PM
91 Z28's Avatar
No. The ECU switches them to ground to fire. You take the ECU 12v away and use your new 12v from the battery.
Old Jun 5, 2025 | 11:03 PM
LSswap's Avatar
any solution? I’m currently facing 6v at my injector connectors on my 04 Pontiac gto and been trying to figure it out for about a month now. Figuring it’s a shorted wire but I don’t know where?
Where are you measuring 6 volts? If you want help, it's better if you're specific.
Are you measuring it at the 12 V feed lines?
Are you measuring it across the injectors?
Is the car running?
Are you using a voltmeter or a scope?
All these things make a huge difference.
