Injectors too small
The 243 heads have the same ports as the 317's that came out. So the cam is the main difference
How do you know the present injectors are maxed out?
https://documents.holley.com/techlib...l_injector.pdf
here’s a good link to learn about injector frame (dimension) differences
https://www.ictbillet.com/swap-guide...e.html#cat-567
Another option would be LS2, they are 33 lb/hr.
