What size injectors
Old Feb 18, 2022 | 07:01 PM
rll2's Avatar
Default What size injectors
I have a 97 Z that I'm trying to finish my LS swap, Part II (long story)
The motor is a 6.0 truck block and crank that has been bored .065 with 6.125 rods, GM ported L76 heads, FAST 102 LSXR intake, Holley Sniper 102mm throttle body
Comp Cam: ADV DUR 277 / 285, DUR@.050 227 / 235, LODE SEP 113, LIFT 613 / 620 and TSP 1 7/8 headers
I did just get a set of Comp 1.8 roller rockers, this will change the cams LIFT to 649 / 656
I have a set of the stock LS3 injectors, but wasn't sure if those will be big enough for the the change in the valve lift and the larger intake and throttle body
I did have a GM LS3 intake, fuel injectors and fuel rails with a 92mm throttle body on the motor before
When I took it to the dyno, guy said I wasn't getting enough air
But thought a lot of it could have been due to the junk CAI (long story)
Thanks,
Rob
