Full Fuel System Upgrade
Old Feb 21, 2022 | 02:21 AM
CatFishSuperSlow's Avatar
Default Full Fuel System Upgrade
Hey all, i have a 02 SS Camaro N/A making around 447HP thats on a completely stock fuel system. I feel that once im give the fuel system a make over, I can have all that my car has to give. I just wanted some help choosing good parts and what should i get. Any help appreciated
Old Feb 23, 2022 | 04:26 PM
theunderlord's Avatar
Is your engine stock? What are your plans?
You want to taylor your fuel system to the amount of power you're trying to support.
Old Mar 5, 2022 | 10:58 AM
.boB's Avatar
The stock system is actually pretty good. You don't need to spend a ton money here.
I have a warmed over 5.7; intake, heads, big cam. Makes about 450'ish on the chassis dyno (it has not been tuned recently). I run nothing but E-85. I'm using an in tank 240lph pump, 10mm nylon lines, Corvette filter/regulator, stock crossover, and bigger injectors. I run it lap after lap to 7K, and fuel starvation is not an issue at all.
For pump gas, I doubt you would even have to increase the size of the fuel lines or injectors. Just put in a quality high volume pump and be done.
Fuel System – Racing the Exocet
Old Mar 12, 2022 | 03:37 AM
LilJayV10's Avatar
I made very similar power with a racetronix 255 pump w/ hotwire and 28.8lb injectors and was in the low-mid 90% IDC.
I'd check your injector duty cycle to see if it's really worth doing.
Old Mar 15, 2022 | 03:44 PM
tech@WS6store's Avatar
LS1Tech Premium Sponsor
We have everything you need there! Give us the entire build info and we can you a recommendation!
WS6Store
