too high of duty cylce??
1st question - how much, if any, hp is this costing?
2nd question - I have a brand new set of DEKA 80s on the shelf, would that be overkill or can I tune for them?
Car will eventually have a turbo, currently collecting parts.
I think he said the guy charges like 25 bucks per injector, which sounds cheap considering how hair pulling it is to try and get a car to run right with a mismatched injector. Especially when your entire car is running off of one O2 sensor.
You're at or near the limits of your fuel system at 5k RPM. The higher the RPM, the less time your injector has to inject fuel into the combustion chamber. You can expand the capabilities of your fuel system (reduce duty cycle) by increasing size of injectors or increasing base fuel pressure. Since you have 80lb injectors, you should toss them in and start tuning/logging with them.
