Engine woes or fueling issues?
Have not even tried to start the engine since. Tonight I may try and drive it down the street to my new house but other than that it is off
I drove the truck around though and it seems to drive decent except very very randomly it will seem to just die and then come back to life.
In his words "changed cylinder mass and VE for a 6.0 (lean issue). Timing tables were pretty **** fixed that. **** ton of idle spark with zero under or over adjust (hence bad jumping idle), fixed that. Drop flow to 22#s (hence it dumping fuel with 44# and stock VE tables going lean."
Truck drives and idles fine now, no power loss and AFR looks good although it idled rich for a minute or two. BUT the truck still smokes especially at idle, driving around I can't really tell. 2 month old gas now though so maybe that? I think the tune could be slightly improved, since it was an email one, but what do I know.
I wonder if all the smoke is not just residual **** in the tail pipe.
I think the tune was a crutch for the real issue. Pretty sure I pumped water at a gas station rather than fuel. I got my tune set up and changed it up slightly and I think I was just compensating for the bad fuel.
It was pointed out to me that I was having a lot of knock in the low RPMs. I figured that was just false knock but I pulled timing throughout the low and it didn't go away. I added a can of race gas concentrate and suddenly all that low end knock basically went away. Still have a little bit but way different than before.
Today I am going to switch back to my original tune and go pump some 93 from a different station. I don't want to jinx it yet but just wanted to add to the thread.
No logs cause I'm in my own echo chamber lol
