Help with fuel system
Old Sep 9, 2022 | 10:18 AM
69PrimedC10's Avatar
Default Help with fuel system
I've got a 93 Trans AM that I am LS Swapping. I pulled the complete fuel system and wiring from a 99 Trans Am. I'm building a 6.0 Lq9 with a Huron Speed turbo kit. My plan is to use the Hellcat 495 pump assembly. Since I am running boost would I need a boost referenced regulator or is that just needed for dual pump assemblies? Could I just run a c5 filter/regulator with a block off in the pump assembly or would I need to buy an external regulator with boost reference? Thanks, I appreciate any help I can get! Tim
