Trouble starting when car is hot
Old Oct 5, 2022 | 09:47 PM
Camarocatfish's Avatar
Default Trouble starting when car is hot
I know there is an issue either with the fuel pressure check valve or regulator I have put a fuel pressure gauge on the rail when the car is off and it has 0 pressure when the car is cold it has no issue starting up but when warm it has to turn over for 2-5 seconds to start I would appreciate it is there is a diagram to find the fuel pressure check valve or is it the regulator in the pump thanks in advance.
edit: I believe the check valve is built in the pump correct me if I'm wrong
Old Nov 9, 2022 | 03:23 PM
rpturbo's Avatar
What is this on? F body, Truck, swap, what year?
I believe there is a checkball in the pump itself to keep the fuel pressure in the lines when key is off, but the regulator is up on the fuel rail. There's a couple different ones depending on year / model
Old Nov 9, 2022 | 04:27 PM
WHY does there need to be pressure when the key is off?
As soon as you turn the key to start, the pump is on and pressured up in a split second.
