98 ecu injector limit
Old Oct 26, 2022 | 02:17 PM
CarcaineAddict1776's Avatar
Default 98 ecu injector limit
Do the 98 ecus have a 8g/sec limit on injectors?
i put deka 60s in my car that was running fine on stock injectors, but with high duty cycle. I put in some injector data and it drives around ok, but if I give it any sort of aggressive driving it just hits dead lean no matter what i do for fueling changes. I heard about this limit only recently. What fixes are there? I have some 0411s sitting on the shelf i can swap in if the issue is the limit in the ecu(after repinning the harness of course)
this is verified with an AFR gauge. Racetronix pump if it matters.
thanks!
Old Oct 26, 2022 | 10:20 PM
FrankieD's Avatar
Unless you're making more than 750hp then there must be something wrong in your tune. Post up your tune
