LS Run Stand - Fuel Pressure Issue
Old Apr 3, 2023 | 03:07 PM
sdaubert's Avatar
Default LS Run Stand - Fuel Pressure Issue
I made a universal, portable LS run stand that allows me to start and monitor LS engines at junkyards, driveways, or car shows. My fuel cell uses an OE in-tank S10 fuel pump that should deliver 60psi (VIN W) before the regulator on the fuel rail. However, I only get 52psi key on, not running and 45psi at idle. Engines idle fine but will not rev. Before I buy/make a better fuel cell and fuel delivery system, what am I missing that's preventing engines from revving past 750rpm? What I have and have checked so far:
  • Stand alone harness with under hood fuse buss eliminated but OBDii port functions
  • Pump filter sock is clean, pump is 1/2 submerged in fuel
  • I have pressure fittings/gauges at the pump and at the fuel rail, both read the same
  • Injectors are dry at 52psi
  • Actively misfiring on all cylinders at idle on HPTuner scanner
  • No thrown codes other than P0300
  • Pump ground has continuity, 12v at the hot grey wire from stand alone fuse buss. Tank fuel level and low voltage signal wires are not employed.
  • LS truck return fuel rail set up (not returnless)
  • Converted to drive by cable with wiring harness mods and ECU rewrite
  • EVAP and EGR deleted
  • WB O2 sensors are on, MAF in use
My daily is an S10 with an LQ4. In that I have a C5 regulator and returnless intake. Key on, engine off fuel pressures are 58-60psi at the rail with this same OE S10 pump as my run stand. No problem with revs in my S10.
Is my pump bad or am I missing something?
