Fuel rails
Old Apr 23, 2023 | 09:05 AM
thefastlife's Avatar
Default Fuel rails
I can not find -10 fuel rails? Anyone know a company or have any?
Thank you for any help.
it’s a BBC with a 104 and we switched to e85
Old Apr 25, 2023 | 01:12 PM
turbolx's Avatar
Lots of fuel rails are 5/8" ID, which is the same as -10AN lines. The only hiccup is that they typically have -8AN threaded fittings like THESE.
The restriction to a single -8AN fitting per side should not really be an issue if you are feeding them with a Y-block from an appropriately sized feed line.
Old Apr 26, 2023 | 12:01 PM
Default Fittings
Aeromotive is being weird and wants the -10 fitting per side. It’s the 10gpm pump on e85
