Relay or Relays to Injectors?
Old Aug 6, 2023 | 10:36 AM
Ncookiii's Avatar
Default Relay or Relays to Injectors?
If this is the wrong Forum let me know , for this question. It has to do with Fuel Injector wiring. Om my 2000 Tahoe I show in the Diagram, 2 fuses. Each fuse covers 4 injectors. I'm starting from scratch wiring this 2000 Tahoe in my 88 Landcruiser. Should I also have two relays?
Probably a really dumb question, I have very little understanding of the fundamentals. I've completed the Fuel pump relay and the starter relay and those are working great, now I'm on to Injectors, Coils etc.
I have The Diagram (Diagram 1) showing the Under Hood Junction Block. IT shows two 15A fuses for the injectors. I can't find a diagram showing how the relays play in.
Any help or links are much appreciated. Thanks guys.
Since the fuse would be between the battery and pin 30 on the relay, I guess I would need two relays and veach relay would handle 4 injectors and each set of 4 would have a 15A fuse. Am I thinking correctly on this?
Last edited by Ncookiii; Aug 6, 2023 at 11:13 AM. Reason: Update to relay question.
