Return and return less fuel lines
Old Nov 15, 2023 | 04:10 PM
shedtech's Avatar
Default Return and return less fuel lines
Hello,
i put a 2001 silverado 4.8 vortec engine in my 65 Acadian, it had 2 fuel lines coming from the tank up to the fuel rail, i installed a new fuel tank with an intank pump and an FPR in the line about 12 inches from the tank, i have 1 line running from the FPR to the fuel rail,
i then welded the the end of the steel part of the return line, my question is, is that going to work or do i have to replace the fuel rail with a 2004 return less ???
if so do i replace both rails or just the left one.
thank in advance.
Old Nov 17, 2023 | 10:54 AM
Old Buzzard's Avatar
The welded tube will work.
Route the return side of the FPR to the tank and set the pressure.
Done.
