Heads/Cam LS3 W/255?
Old Nov 28, 2023 | 09:59 AM
gjohnsonws6's Avatar
Default Heads/Cam LS3 W/255?
Current set up: heads/cam LS3 on gasoline, has anyone pulled this off with a 255/hot wire? I have a new re worked 340 system with an external regulator and lines however there are plenty of reasons to keep it in that different F body at the moment. I am also running a 170 amp alternator that might make a difference in this combo as well.
Old Nov 28, 2023 | 01:49 PM
02EBC5Z06's Avatar
That setup doesn't need anything big. A 255 is more than enough.
Old Nov 28, 2023 | 02:50 PM
Thanks for the input. 👍🏻
