No Fuel Pressure
Old Feb 12, 2024 | 08:23 PM
Bbknucks's Avatar
When you have the jumper wire in to get your 60psi it starts and runs?
Old Feb 12, 2024 | 08:34 PM
Tootsie9's Avatar
Sure does the pump runs and I keep a solid 60 psi when I use the jump wire but when I use the relay my pump only gives me 20psi
Old Feb 12, 2024 | 08:45 PM
Bbknucks's Avatar
If the engine starts and runs with a jumper in the relay spot then you have an issue with relay or the control side of the relay... you can use a headlight bulb across the control side of the relay terminals and if it's bright when you key on then it's good and if it's dim then you have a problem there... you can then narrow it down to the power or ground side
Old Feb 13, 2024 | 01:05 PM
Tootsie9's Avatar
ok not familiar at all with something like that but I will give it a try. thanks
Old Feb 13, 2024 | 05:57 PM
Old Buzzard's Avatar
That's what volt drop tests are for.
Old Feb 13, 2024 | 06:11 PM
Tootsie9's Avatar
I’ve never done one but I’ll hit the googles and try it out
Old Feb 13, 2024 | 06:23 PM
Thumbs up Good idea!
Easy to do. Google will show you the way.
As mentioned, it could be the relay, the relay ground, the 12v source.
Old Feb 13, 2024 | 06:24 PM
Tootsie9's Avatar
Thanks man I appreciate it
Old Feb 16, 2024 | 12:54 PM
Tootsie9's Avatar
Ok so I finally got around to doing the drop test and here are the numbers. Hopefully someone can tell me if they are good or not. Ill start with the ground side:
Key off: KOEO:
Pin 1 .005 V Pin 3 .005V Pin 1 .05 V Pin 3 .03 V
Pin 5 12.56 V Pin 2 .005V Pin 5 12.25 V Pin 2 12.02 V
Power side
Key Off KOEO
Pin 1 12.59 V Pin 3 12.6 V Pin 1 12.27 V Pin 3 12.3 V
Pin 5 .001 V Pin 2 12.00 V Pin 5 .01 V Pin 2 .25 V
I installed an aftermarket FPR and the pressure gets gauge reads pressure. I installed a walhbro 255 fuel pump so everything is new. Ive got a 98 which had the stock FPR in the tank on the return but since I added the asdjustable one in the engine bay I can just chuck the old one correct?
Old Feb 16, 2024 | 01:56 PM
Bbknucks's Avatar
Kinda confusing the way you wrote that out but...
Pin 1 and 2 are the control side of the relay
One should be ground all the time and one is power from the pcm
Voltage drop should be tested with the load on the circuit. An easy load test is to use a headlight bulb across those pins. When you key on the bulb should light brightly during the pump prime cycle for like 2 seconds. If it's dim then you can put that bulb between the ground side of the relay and battery positive- should be bright - if so then swap the bulb so it's on the power side of relay and battery negative then it should light brightly during the prime cycle.
This tests circuit integrity quickly. A poor Connection or bad wire will show full voltage and low ohms unloaded but not be able to support the current requirements when loaded with an amp draw
Old Feb 16, 2024 | 02:00 PM
Tootsie9's Avatar
yah sorry I wrote it up different but when it uploaded thats that it showed. Ill try the bulb thing
Old Feb 16, 2024 | 02:16 PM
  #32
Tootsie9's Avatar
Bulb is bright when i use ground side of the relay and battery positive. Equally as bright when i use relay power and battery neg
Old Feb 16, 2024 | 03:23 PM
  #33
mk3cn4's Avatar
Since you mentioned you have a bulb handy, here is best way.
Put a bulb with leads in 1 and 2 (as shown on the relay picture).
Just sitting, the light should be OFF. Key off, then key on and you should see the bulb light for right around 2 seconds and go out. That should happen on each and every key cycle. Bulb should be bright and solid for 2 seconds then go off.
Then when you crank it you should see the bulb light again only while engine is spinning.
That tests the control side.
Your jumper has already tested the load side I believe, I think you said if you jumper 3 to 5 the pump works.
If this all works then your relay is broke. If not, then find out why, maybe bad power isn't lighting the light etc....
Note: I am basing these pin numbers off of that relay pic. If you have the wrong relay then the pins may be different, I didn't look up the fuse box ping numbers I am trusting that relay pinout.
Old Feb 16, 2024 | 03:29 PM
  #34
Tootsie9's Avatar
When I justr use pins 1 and 2 with the key on but engine off the bulb doesnt light up
Old Feb 16, 2024 | 03:58 PM
  #35
Tootsie9's Avatar
I appreciate all the help. I have pressure just weird how it never goes back to the same psi . I havent been able to start it because for some reason my injectors arent pulsing. Ive got 12v at the red wire on the injector coil when KOEO and i ground the multimeter to the neg battery. When IU test the ground on the coil its 6.65 so idk if thats right or not. I have checked all the grounds and cant figure it out but the injectors wont squirt
Old Feb 17, 2024 | 09:45 AM
  #36
Bbknucks's Avatar
So the car never started with the jumper in the fuel pump relay like you said it did?
Old Feb 17, 2024 | 09:46 AM
  #37
Tootsie9's Avatar
It did for like 2seconds then died
Old Feb 17, 2024 | 09:56 AM
  #38
Bbknucks's Avatar
Really dude? Is that repeatable? Starts and runs vs ran for 2 secs and died are completely different... thats why you got people running in circles telling you how to test the control side of a relay when bypassing the relay didn't even fix your no start issue...
Old Feb 17, 2024 | 09:58 AM
  #39
Tootsie9's Avatar
Sorry man I felt like that put me on the right track. And it did start multiple times then died just not consecutively. Like in order .
Old Feb 17, 2024 | 11:06 AM
  #40
Bbknucks's Avatar
You have a scanner of some sort? Check for rpm and a cam signal and any codes
