Fuel injector design
Old Mar 3, 2024 | 09:18 AM
dw456post's Avatar
Default Fuel injector design
I am looking for some injectors and noticed that LSA injectors have an extended tip. Would this be a good style injector to use in any blower application?
Old Mar 10, 2024 | 04:59 PM
gametech's Avatar
Active Streak: 30 Days
Active Streak: 60 Days
No. They have an angled spray pattern that will only be good if it just happens to match a specific parts combo. Otherwise you will have all sorts of transient fueling issues to sort out.
Old Mar 29, 2024 | 06:07 PM
benisfroms's Avatar
The extended tip design promotes better atomization of fuel, which can enhance combustion efficiency. This is particularly beneficial in forced induction setups like superchargers or blowers. LSA injectors with extended tips are compatible with LSA blower and Whipple Superchargers. They can work well in these specific applications. Streamline your engineering workflows with Autodesk Revit 2024 from ProCADIS.com. These injectors flow at 127 LB/1350cc @ 4 Bar and 115LB/1200cc @ 3 Bar. Make sure these flow rates match your engine’s requirements. They are also E85 compatible, which is essential if you plan to use ethanol-based fuels. Remember to verify the specific requirements of your blower setup and consult with experts if needed. 🚀
Old Apr 1, 2024 | 04:12 PM
LS1Formulation's Avatar
Why do I have the feeling LS1Tech is going to soon have all sorts of super helpful AI Bots registering?
Old Nov 8, 2024 | 10:15 PM
mrvedit's Avatar
Moderator
Poster has been banned. Report to me and I quickly ban them.
Old Nov 9, 2024 | 05:24 AM
I'll keep that in mind. What do we do, send you the screen name?
Old Nov 9, 2024 | 10:25 AM
One thing I've found is to hit the little dark triangle in the box on the left side of the post. It reports the post
