lt1 fuel injectors
Old Apr 21, 2024 | 05:08 PM
stingr's Avatar
Default lt1 fuel injectors
I'm looking for a set of injectors for my 97 Lt1. I'm going to be running about 6-9psi of boost and a inline fuel pump along with the stocker pump. Any recommendations on decent injectors that aren't crazy expensive for a set? I'm thinking something in the 40lb range should do the trick.
Old Apr 21, 2024 | 10:36 PM
madmike90's Avatar
Depends on the rest of your combo and how much power you’re expecting to make. From what I recall, a 42lb injector is completely maxed out on a boosted LS around 500ish whp. Even if you’re planning on being around 500whp I would run a bigger injector anyway to keep the duty cycle lower
