Injector identifying
Old May 2, 2024 | 01:29 PM
bwfab's Avatar
Default Injector identifying
Need some help identifying the injectors that are in this newly aquired 2002 Trans Am with a STS rear mount turbo. The system has a Kenne Bell BAP system and im not sure what pump, as i havent had time to pull the tank out to check yet. Also if anybody has any info on what tuners were commonly used for the STS set up that would be great as well. The person I got it from didnt have any information for this set up and I spoke with the owner previuos to him and he did not have much info other than telling me about the BAP setup. It has AFR heads and a supposedly built forged rotator. I have not veerified the rotating assembly yet but it does have heads that are engraved AFR on them, but cant find any other casting numbers on the outside of them. Look forward to hearing back from you all.
Old May 7, 2024 | 02:38 PM
dw456post's Avatar
That must be a serial number---can't find that number
Old May 7, 2024 | 03:20 PM
bwfab's Avatar
thanks for looking
