LS7 injector to LS1 adapter
Old Aug 26, 2024 | 03:05 PM
99_Z2Eight's Avatar
Default LS7 injector to LS1 adapter
I have a FAST 102 LSXR intake with LS2 fuel rail. I also have LS7 injectors, which I know are short and have a different connector. This is going on an LS1. Any help or guidance with a link to find the adapters needed to connect these to the factory harness would be greatly appreciated. I searched google all weekend and couldn't seem to find anything.
Old Aug 26, 2024 | 08:26 PM
the_merv's Avatar
Veteran: Air Force
They are all over eBay..EV6 to EV1 Adapters.
Old Aug 27, 2024 | 12:17 AM
gametech's Avatar
Active Streak: 30 Days
Active Streak: 60 Days
Ebay, Amazon, and thousands of other links come up on any relevant Google search. If you are not lying and you really tried all weekend to find them, give up now. It will take you several thousand years to finish this project.
Old Aug 27, 2024 | 12:36 AM
99_Z2Eight's Avatar
I’m a dummy. I didn’t realize the male ends on both ev1 and ev6 looked so similar. All the connectors I looked at seemed like the ev1 male end was the same as the ev6 connector. Problem solved. 😅🤦
Old Aug 27, 2024 | 01:00 AM
gametech's Avatar
Careful which ones you order. They make adapters to convert in both directions. I almost clicked buy on some that were backwards to what I needed once.
Old Aug 28, 2024 | 04:53 PM
LilJayV10's Avatar
I'd think ICT Billet would make them.
