408 stroker fuel pressure dropping.
If so, look for a leak at the hanger connection hose.
Cavitation caused by poor/no tank vent will kill the pumps.
Low voltage will kill them, too.
Insufficient pump sock to bottom of the tank will cause cavitation, also.
Pressure may be sufficient as long as minimum fuel is called for.
" as well as clogged fuel lines". The hose liner may be failed, and a "flap" is pulled over the opening when hi volume is called for.
What kind of lines are you using?
Does the cell have foam in it?
