Need bigger fuel injectors?
Old Oct 24, 2024 | 09:35 AM
Rockitansky's Avatar
Default Need bigger fuel injectors?
Hi all, I have a 2002 corvette track car with a LS3 495hp crate engine with OEM GM 430hp fuel injectors and intake and 90mm GM throttle body. My question is do I need bigger fuel injectors, especially when it runs at hi rpm all the time? THX Brian.
Old Oct 24, 2024 | 10:22 AM
If your present ones aren't leaning out on top, you likely do not need larger injectors.
Old Oct 24, 2024 | 10:39 AM
Yeah I was wanting to change F/I's out, if needed, before I ran it on dyno, but as of now I have no dyno data. THX tho.....
Old Oct 24, 2024 | 12:13 PM
68Formula's Avatar
Should be. They have a lot of headroom. Can depend on factors such as whether you've added a power-adder, flex-fuel, and target lambda. Get an OBDII reader and monitor the duty cycle @ redline/WOT. They'll handle up to 90% duty cycle easily.
