Multec to EV6 injector swap
Old Oct 29, 2024 | 05:47 PM
Jake Wade's Avatar
Default Multec to EV6 injector swap
Can someone tell me how I can adapt EV6 injectors #12609749 to my 2006 Silverado that has Multec 25lb injectors?
I know I need adapters for the different connectors but, what about the difference in the height of the injectors?
The Multecs are 47mm and the EV6 are 38mm.
I put a 6.0 in the place of the 5.3.
I am using the factory truck intake that came on the LM7.
i realize it will need a tune.
Thanks
Lonnie
Old Oct 31, 2024 | 11:35 AM
Full Power's Avatar
"adapt EV6 injectors #12609749 to my 2006 Silverado that has Multec 25lb injectors?"
If you have the EV6 connectors (pigtails) in hand you can use rosin core solder, 3/16" heat shrink tubing, and a small- medium size soldering iron to splice the connectors into your harness; there's plenty of room to work in, and the POLARITY is not critical.
Or, if you don't want to CUT: call up SUMMIT Racing for a set of adaptor pigtails.
Old Nov 1, 2024 | 10:01 AM
Jake Wade's Avatar
Thanks for the reply. I have the electrical figured out. I need spacers for the injectors. They are too short to meet the fuel rail. There is 9mm difference in length.
Old Nov 1, 2024 | 10:19 AM
Any way to shorten the rail mounting standoffs to accommodate this?
Old Nov 1, 2024 | 01:00 PM
Jake Wade's Avatar
The top of the fuel rail where it crosses over the top of the intake is very close as is.
I found that ICT Billet makes the extensions.
