Return style fuel system
Old Jan 9, 2025 | 09:02 PM
7cutlass2supreme's Avatar
Veteran: Navy
Default Return style fuel system
there may be a thread for this but i could not locate it.
the fuel rail on my LS1 has two ports on it. feed and return. can i plug the return and use the corvette style regulator as the return so i can run just one line to the engine without damaging the engine.
Thank you
Old Jan 10, 2025 | 03:19 PM
Full Power's Avatar
The rail mounted Fuel Pump Regulator works VERY VERY well for referencing fuel rail pressure to Intake Manifold pressure, which is a GOOD feature.
All of your injector flow data goes OUT the window with "fixed fuel pressure"
Old Feb 11, 2026 | 06:03 PM
Veteran: Navy
Thanks for the reply! appreciate it.
