Early pwm system woes.
I am building a Silverado for a gentleman. I used a racetronix hot wire kit for two pumps that has a Hobbs for the second pump. The pump plugs in and gets power to the relays via the alternator. The issue is that this was a returnless system but I did not see a FPCM mounted under the bed. Where else could the controller be? Single cab 04 Silverado. It doesn’t have a communication loss DTC either. I’m looking to bypass whatever the control function the truck has as it is a return style fuel system now. Any suggestions on how to get that accomplished would be great!
