Best Throttle body
Old Mar 22, 2025 | 05:43 PM
Perry LaBarbera's Avatar
Default Best Throttle body
Well, I fell into the trap, I tried to use an incompatible throttle puddle assembly 19417903… so that’s straightened out with my terminator X… what throttlebody have you guys found is the best to work with a terminator X?.. 90 mm… I currently have a 12679524… I actually have a pair of them, but I don’t think they’re compatible either.. need a six pin of course thank you
Old Mar 22, 2025 | 06:54 PM
Which engine? Heads? Cam?
Most of the time a stock TB works as they are usually oversize for the engine they come with.
Old Mar 24, 2025 | 12:22 PM
Hi
Finally had a chance to answer! I have a L92, with a BTR LS3 V2 cam, 823 heads, milled down .015, LS7 head gaskets, LS3 intake
I already am using a 12679524 throttle body and do not need to switch unless the Terminator X Max does not support it, They do not list it as compatible/supported , however some others online say it will work fine . I answered my own question about the throttle pedal as I had purchased a assembly from Holley two years ago( forgot where I had bought it) . I am finally finishing this project up! I see the GM part number they use for the bracket, not the TPS. I WAS able to do a throttle learn with the wizard, and it synced up just fine. I was searching if there was a way to "cycle" the throttle body with the V3 software, to verify it will work. Maybe I never got the right forum The Holley comes with a six pin. KOEO, makes a little sound, moves just a hair, but I would think that is normal, without the ECM seeing engine running.
Thanks
