Quiet inline pump?
Old Mar 27, 2025 | 07:28 PM
stingr's Avatar
Default Quiet inline pump?
Is there a good inline pump ot there that is fairly quiet? I have a walbro 255lph knock off that really is quite loud. It gets on the nerves a little after driving for a few hrs.
Old Mar 29, 2025 | 03:35 PM
LS1 TJ's Avatar
Not trying to be a smart aleck but maybe because it's a 255 knock off its loud?
On my my early LS swaps I used Bosch 044 external pumps. You could hear it at idle but going down the road you couldn't hear it at all.
Old Mar 29, 2025 | 03:50 PM
Keith's Avatar
Supposedly turbine style fuel pumps are the quietest. I'm not sure of an inline pump that uses a turbine impeller though.
Old Mar 29, 2025 | 08:32 PM
stingr's Avatar
honestly that's kinda what I was thinking. I may switch to a genuine walbro pump.
Old May 7, 2025 | 09:59 AM
stingr's Avatar
I just installed a REAL walbro inline 255lph pump. It's a night and day difference. Nice and quiet. When I held the two pumps you could tell the walbro pump was a bit heavier. It's so much nicer driving the car now and doesn't sound like a dentist drill in your ear all the time. Glad I changed it. Hope this helps someone else make a decision on the pumps.
Old May 7, 2025 | 11:01 AM
Forcefed86's Avatar
How do you have it mounted? That’s usually the biggest factor noise wise on a pump installation. The walbro inlines aren’t generally loud pumps. If you use rubber insulated clamps AND the use a rubber isolator, noise *should* be minimal. I can’t speak for knock off pumps. I can tell you the AEM400 inline is a loud **** compared to the 255 inline. But if you insulate it with rubber and use rubber isolators it cuts the noise levels way way down.
Old May 7, 2025 | 02:38 PM
stingr's Avatar
the knockoff was loud and real one is quiet. I have it on a bracket i made with rubber mounts. It's all pump for noise in this case.
Old Jul 1, 2025 | 02:45 PM
Full Power's Avatar
Magnuson kit supplied a frame rail mounted Inline 044Bosch, in operation since 2016 with NO Problems. Gets a bit loud after long hoghway run, when tank level goes below 1/4 Probably cavitates some, primary stock in tank pump likely sucks the bucket dry.
 Michael S. Palmer
