P0200 code
Old Apr 12, 2025 | 11:59 PM
arslsx's Avatar
Default P0200 code
Hello everyone. I am trying to figure out a problem with my injector circuit.
As I was tuning the LQ9, I couldnt get it to run right, even though I got my VE table in order and my afrs where I want them. When driving, especially uphill, I hear a backfire and there's a lack of acceleration. The engine doesnt want to spin past 2600 rpm. I was thinking the issue was the tune, but as I continued driving, I got a p0200 code. I tested each connector with a noid light, and it flashes on all. I tested the resistance on all injectors. Each one of them is about 14 ohms. Is it a failed pcm?
Old Apr 13, 2025 | 01:45 AM
gametech's Avatar
Active Streak: 30 Days
Active Streak: 60 Days
Anything is possible, but it is almost never a failed PCM. Normally a broken or corroded wire is the culprit.
