L59 injectors upgrade?
Old Sep 2, 2025 | 04:00 PM
MudDAWG's Avatar
Default L59 injectors upgrade?
Got an 05 L59 intake and injectors. They’re rated at 36.6 lbs/hr @ 58psi. I’m looking for an easy swap in injectors rated around 50 lbs/hr. I’m getting conflicting and confusing answers from different sources (forget about AI help) but even info from injector and speed part shops have conflicting information. Are LSA, LS9, LC9, LMG, L9H, L94 or L96 direct replacements and are they 52 lbs per hour? I read multiple different sites and found multiple different answers…
Old Sep 6, 2025 | 11:39 AM
gametech's Avatar
Active Streak: 30 Days
Active Streak: 60 Days
https://www.ictbillet.com/pages/auto...RiaRjANa3lFOZH
That should help some. There are still other issues such as LSA injectors having an angled spray pattern, but that link gives most of the needed info.
edit-- Some flow rate differences with the same injector are because of a few vehicles that used 51psi base pressure instead of 58psi.
Old Nov 1, 2025 | 08:22 PM
G8 Drew's Avatar
You’re going to need a serious fuel pump upgrade. With LSA 54lb injectors your pump must put out 300 L/hr. Going single or twin turbo?
Old Nov 17, 2025 | 04:40 PM
Full Power's Avatar
Make it easy on yourself: @ deatschwerks
Eight injectors, with data.
Write the check, enter injector data, drive it away.
It really can be that simple.
